If you're using go launcher like I was, you will probably find out your having a lot of reboots and lock ups. I was under suspicion that go launcher was causing the issues so I decided to try holo launcher.
I've been on this launcher for a week now and had no lockups or reboots, and the phone run smooth and fast like it should like I expect from a phone. S o it might be worth a shot to try this holo launcher and see if your problems dsappear as well as mine did.
I hope this help somebody out because I'm sure glad I found it, makes me really love my warp again.
on a side note my uptime says 351998:43:20. not sure if that's the correct hours of the up time, but that's what it says under about phone, status scrolling all the way the bottom showing the up time. Is that correct? all I know it is been up about 7 days uptime. it's like I have a new phone all over again.
