Is anybody using the Seidio wall charger to charge the battery out of the phone?![]()
Do you see a difference in the battery life when you charge it on your wall charger?
I have the Seidio wall charger for my DI and got a longer charge out of both the OEM & Seidio battery over using the charger in the phone. Is anybody else getting there results?
So with the external charger whats the life on the TB?
Bluetooth and WiFi are both off unless I'm using the hotspot (which, I guess is a different kind of WiFi...)
I'm getting much better time now. On a day when I do not use the hotspot or navigation, I'll be at 35-40% after 10 hours. I'm not going to try and A-B with the HTC battery for awhile. I'll let the Seidio burn in for another week and then maybe switch.
So far I'm happy. That doesn't mean that I would have been less happy with the stock battery.
FWIW
DLM
