My wife recently bought a Galaxy Tab 7.7 and now after some hours of experiance she has some questions:
1. When you turn off the sound it doesn't turn off everything, sounds on webpages still plays.
2. The screen unlock pattern is in the same place so it's easy to see it because of the grease the finger is leaving behind.
3. When you want to edit text in the web browser, for instance in a forum like this, and you put the marker where you want to start edit, the marker jumps 1 or more letters efter about one second. It's not a miss click, because you can see that the marker is in the correct place when you remove your finger, and then after about one seconde it jumps to another place. Extremely annoying.
4. Honeycomb does not utilise the screen size, it seems like it's made for a smaller phone with lesser resolution. Reminders and other notifications is easily missed. Text is also extremly small sometimes and even though you can read it, it's very hard to put the marker in the right spot, if you want to mark and copy a text for instance.
5. Reminders from the calendar is to discreet, it should be something that you have to turn off manually so you dont miss it.
6. Can you create a shortcut to a file on the startscreen/desktop?
7. The clock doesn't show when you make a call so you can't check the time
8. The screen locks itself quickly when you make a call, in like 10 s, even though you have set it on 5 mins. Very annoying when you want to check things on the pad during a call.
9. Adding a new phone number to a contact is very unlogical, and it takes alot of steps. Why not just have, "add phone number to contact" when you have marked the number??
10. You can't set the timer on an certain amount of hours and/or min, just a time?
11. I can't write
11. I can't write
