devilschild26
Android Expert
U don't need to be rooted to flash the update zip just pay attentionIm not rooted yet though.
U don't extract the zipYes...but I downloaded the new zip and extracted it...how to flash?
NopeDo you HAVE to have an sdcard to download rootrashr.zip?
http://androidforums.com/threads/root-help.911913/ read this in no time u will gain root
Well u can flash twrp then flash b07 zip to prevent updatesThanks for the info. Since it's going to revert back to B04, if I don't want to install a custom ROM, after rootedthe B04, it'll keep prompting to update to B07, is there a way to stop the update reminder if I wanted to stay stock (rooted)? it's so annoyed to see the popup reminder every few minutes.
But that would unroot if i flash the 07 zip, right?Well u can flash twrp then flash b07 zip to prevent updates
Nope u will still be rootedBut that would unroot if i flash the 07 zip, right?
U will still have rootBut that would unroot if i flash the 07 zip, right?
I just posted the link for the b07 optDeleted
Thanks a lot.U will still have root
Ok, got it. Thanks a bunch!U need to use twrp not stock recovery
Won't let me openThought this might be useful for those looking for a reliable guide to doing everything right from the phone.
1. Download and install RommasterSu zip below and install it and gain root. It is in chinese and will install proper root using a superuser app they like to call "Kinguser". Dont worry about all the chinese you see..just click the few prompts you see by selecting the buttons that are blue and on right hand side of screen at the bottom..then you will see a little red root button next to a small cartoon character,pick it to gain root..once root is gained move to step two.
2. Download and prepare to install [Root] Rashr below by first downloading TWRP Recovery from here on the forums. Once you have the recovery downloaded and in the root of your sdcard,install this app. You will be first prompted with a disclaimer,select "I know the risk" option and then select the big "recovery" button,and then select "Other from storage"..now select recovery.img [this is your recovery image,be sure to extract it from any zip it may be in,Rashr will need the base recovery img file]from your sdcard and allow the app to flash it,once the app flashes the recovery img it will offer the option to boot in to recovery.. Go ahead and reboot in to recovery and move on to step 3.
3. Once in recovery backup your current rom. Once that is done perform a wipe of cache,dalvik-cache,data,internal storage and system,and finally install rom of your choice and reboot. (Already have one downloaded and ready to try out..) I would suggest something like L Awe rom as something to begin with and you wont be disappointed. It is a well made custom stock rom.
edit: the zips proivided need to be extracted...use an app like root explorer.
also i made this guide after several failed attempts at using the pc methods on xp,vista and windows 7 devices..there was always some conflict between the phones drivers and pdanet on vista and windows 7 and xp refused to sideload anything on my pc and caused the pc to reboot when attempting to sideload...usb conflict...so if you do encounter any issues on your windows devices..this might be just what you are looking for.
Re down load using different browserWon't let me open
I had to extract from file manager. Downloaded L AWE Rom and both filesRe down load using different browser
Thank youuse opera browser. stock android fails.
