Milo Williamson
Extreme Android User
So mine went away after the last update it ever had, so how do I use it again, I have the password inside right now, maybe a fdr..
fdr?So mine went away after the last update it ever had, so how do I use it again, I have the password inside right now, maybe a fdr..
Well I tried it a dozen times, and I see a fingerprint above the pattern and number lock password, still no chance of applying it..fdr?
go into settings>security>fingerprint>add or delete finger
https://motorola-global-portal.cust...od_answer_detail/a_id/150178/p/30,10860,10861
you will need to enter that password to access your fingerprint settings.
