Benchmarks don't necessarily mean faster in everyday use. That's why an Incredible is zippier than an X or Fascinate. Their UIs are slowing down the phone. If they had come with stock android they would be as fast if not faster than the Inc. Sense just doesn't seem to slow down the phone like some other skins do.
As far as it being an Evo clone or just a small step up, it has a newer gen processor and gpu, more ram, more internal memory, a 32GB microsd card preinstalled, a better 8mp camera then the Inc or Evo, a kickstand that works in landscape or portrait (only landscape for the Evo), the ability to do voice and data simultaneously over 3G, and 4G to boot. Plus with sense 2 it has a multitude of features (remote find & wipe, ability to send apps to the phone from htcsense.com, and a 10 second boot time). If you want to compare quadrant scores the tbolt is in the mid 1900 range out of the box.
If you don't want to buy it fine, that leaves 1 more for the rest of us. But you have been bashing this thing since you found out it wasn't dual core. If that's a problem for you, fine. If you're arguing to justify not getting it yourself, I can't help you there. I guess I'm just curious why you're going out of your way to bash something you're not going to use. You'd probably be happier at either the bionic, revolution or samsung 4G forums.
P.S. The info on the camera, sense 2 features, & kickstand is from a youtube vid by one of the testers that was posted here in the tbolt forums by Eazail70x7. Link below
http://www.youtube.com/watch?v=JcsbCA3uXek
