just new cable?
It sounds like you may be using a charger other than the one sent with the phone. If this is the case you must ensure the charger can supply enough current for hte Thunderbolt. Check the output mA rating on the charger (printed on charger). Use a charger with a rating of the original Thunderbolt charger or higher. Symptoms include no charging or slow/incomplete charging.
I have a extended.battery and have original cable ccharger.
