Touchwiz blows a big one. Plus the phone isn't even as powerful as the bolt. If they released the s2 I would more than likely switch but not about to switch to a lesser phone for more $
Have we really become such consumer tools?.
The Hummingbird and the SGX540 are both a bit more advanced than the 2nd gen Snapdragon and Adreno 205; any benchmark will show this. The Thunderbolt's only performance advantage is more RAM.
That said, one thing I like about the Thunderbolt that the Charge does not have is simultaneous 3G and voice. Calls and data at the same time isn't the only benefit this has. The one that I like is that you can be web browsing or downloading files over 3G and your data connection won't disappear/halt for a moment when you receive a text message.
The Droid charge has rfl, witch means it eventually lags like crazy.
After using my Charge for almost 2 week I do no regret making the switch. The Charge has way better battery life, a better display and performs better in games. It also has hdmi mirroring that it works very well.
Actually the Benchmarks show that the Thunderbolt is faster. 1800ish vs 1000ish on Quadrant. The Thunderbolt also has 8GB of onboard memory vs the 2GB on the Charge. Also, both phones are using Verizon's eHPRD so both are capable of simultaneous voice and data.
Quadrant has a compatibility issue with the I/O test on the Droid Charge, that's the only reason the Droid Charge scores the way it does on that test. The Droid Charge is every bit as powerful as any of the first gen Galaxy S phones; all of which are more powerful than the Thunderbolt.
The Thunderbolt has simultaneous 3G and voice because it has two separate cellular radio chips. One is capable of 1X and 3G connectivity and one is capable of 3G and LTE connectivity. The stock configuration of the Thunderbolt uses one radio in 1X mode at all times for voice and the other radio switches between 3G and 4G data depending on which is available. It is my understanding that the Droid Charge does not have both radio chips(and possibly no other phone releasing on Verizon in the future). While it may be possible to have simultaneous 4G data and voice on the same radio, it isn't possible to do it with 3G data and voice over CDMA. Do you have a link that undeniably proves that the Droid Charge can do simultaneous 3G CDMA data and 1X voice?
How were you able to have it for 2 weeks when it was just released? Can you tell us more about how it compares to the TB? Battery life? weight? Do you miss sense? Is their stock software version as bad as others have said?
I bought it at best buy before they knew they were not to be sold. Battery life is way better on the Charge. I have gotten up to 2 whole days out of it. I hate sense, it ties into way too many things in the os. The messaging, gallery, contacts app all suck. The new notification bar with the last 8 apps is also a horrible addition to the os. With the Charge I like the fact that the notification bar has toggle widgets on it instead of something useless like the new sense has. It also has a built in task manager, and native screenshots. The launcher is not as smooth as Sense but it looks like the new ota released today fixes that as well as some other issues. I have not downloaded it because the new update is unrootable as of right now.
