Thunderbolt will ONLY connect to WiFi, not 3g/4g
nguyen18
Member
I think it might have been a result of the GB update. Can anyone help me? I'm frustrated because I need the data to work, i'm not receiving potentially important emails promptly anymore. The only way I can get the data to work is rebooting the phone. Then after a little bit, it stops working again.
For a long time I had my network setting set to CDMA only for battery reasons and there was no 4G in my area. 4G opened in the area I work, but not at home. So I set the phone for LTE/CDMA. It works fine crossing between 3g and 4g in general. But every once in a while, usually at home. I lose the network altogether and have to reboot basically. So I put my network settings back to CDMA only and I haven't seen that issue again.
May not be the same thing, but I thought I'd bring it up.
i just started having this exact same problem about three days ago and i haven't figured out anything that works except rebooting.
