wrap said:I prefer app brain. Just download from the market, sign in and it will sync all your apps. It will not sync the app data though... but its easy and has never given me any problems!
AK said:As far as titanium backup is concerned, make sure it has been grated su permissions (open the superuser app and make sure it's on the list). If so, you should try reinstalling busybox from within titanium backup. If it still doesn't work, press the "Problems?" button.
Yeah I'm using appbrain. For some reason, even though I synced before rerooting, when I synced after the root I didn't get my apps back. I just changed the list. That was frustrating. Luckily I saved screen shots of everything so I knew what I was missing. My other concern is the data though.
Apparently it was a busy box problem. I had "yes do it." 4x before the list was populated. Thanks.
I had it w/ the free version, but it didn't work then either.
