Tiger Arcade Controller Help !! Key Mapping ....
Mr.X
i downloaded and installed tiger arcade and put roms in sd card .........but i cant seem to play the game comes up .....but i cant insert coins to play ....
any 1 how to fix this !!
p.s how do i set up the key mapping .....??
The start/select buttons should be for coins and starting the game, so you need to be able to map the the two tiny slanted buttons that are in the middle (for the Virtual pad).
Actually, I recall having no problem with the control pad when tested the Play in a US VZW. I played Metal Slug.
Tiger Arcade rocks, but still does not scale correctly for Honeycomb- little tiny window :(
