Wally World
Android Expert
Is there any fix for this? Seems to have happened after I did the 228 update. Has to be killing the battery life.
from what ive read about DBA (in general)-1 is better then -100. but with cell phones they say (google) -50 to -70 is good.. im at -87 in my apt and never have any problems except wireless teether is slow. they say dba signal has no effect on download speed, but that is not the case with me...i did a test at my parents house. they have the Verizon 3g usb modem. and it sucks, although i didnt use any speed test sites. just webpage loading, my phone tethered to the pc was noticeable faster then the usb modem, and faster then at my place. signal was at -55.I am seeing a -90dba to -95dba signal at my house. Is this good or bad?
not good..
Try wiping the battery stats in recovery. It usually clears this problem for me. (For awhile anyways).
What is considered good?
That signal is adequate and is NOT causing the 50% "time without a signal" problem.
It's not a great signal, but it's not completely awful. I get -97 at my desk at work (this building is murder on cell phones; my iPhone had no coverage at all) and average about 500 kbps download data speeds
I've seen as high as -62 around town, but I have no trouble making calls with -90 or lower.
Yes, when you click on Cell Standy I get a message on the screen-51% of time without a signal.
Ok, I will try it and report back. Thanks.Ok, try the Airplane mode trick. It "fixes" it until my next power-off (Which just means I have to remember to put in phone in Airplane mode before powering off). Let us know if it works.
