Added!
Any recommendations as to how to get these into the buildprop? I copied them to a word document on my phone to copy to the building prop and the text was way bigger than what had been there and it ran all of the text together.
Also the Dual-Core Mod you posted conflicts with alot of the other tweaks you posted aswell as it turns off the Button Lights try changing it to this Modified One
Dual-Core Mod fix.zip
Ok ill use that one instead, I didnt mind that the buttons were off I know which ones are which
no comments on battery life and camera mod improvements? I'm dying to try the dual core mod and the camera mod but hesitant without feedback.
Awesome! I'm not even sure if the original scripts I uploaded were actually working, I was looking in system tuner and Core 2 was constantly going offline.Cool It also had the problem that CPU settings wouldn't stick if you changed them but thats fixed in the zip I posted![]()
Ive been looking into the files and noticing that. When I get back home i'm going to fix up the zips and take out any duplicate tweaksThe first camera tweak may be irrelevant since both have the same file inside overwriting whichever you put in first.
Has anyone noticed that the stock build.prop (which I've posted in a previous thread) already comes with debug.sf.hw = 1? (This is just one example, there are lots in the stock build.prop) What I don't know is how sticking a line like that in build.prop twice will be handled. How well does Android handle bits like that? I'll wait for a flashable build.prop until I manage to reconcile all of the already-existing lines with these tweaked versions, which could take a good while.
ro.setupwizard.mode=DISABLED
ro.setupwizard.mode=OPTIONAL
I took away the qc.hardware and qc.debug tweaks, as they were actually hindering performance by about 4-8 FPS. My goal now is to get 60 FPS in NenaMark, I'm up to 51.4 FPS right now...
I win lol Mobster Rom V 1.0.4.1 got over 60 FPS
Im going to bed but heres my max FPS for right now, Im using the Smartass V2 governor and there was probably some thermal throttling as I was constantly tweaking, rebooting, and rerunning the tests. This is a first run after my last reboot:
Almost beaten the Galaxy S II T-Mobile, which also had the Adreno 220 but its clocked higher. Imagine what this phone can do when they make a GPU overclocking kernel for ICS!
lol im gonna try to beat this now![]()
Can I apply the tweaks on Stock rooted?
-not the kernel, I love 3D imaging.
lol ok its a race to 60 fps in nenamark 2!![]()
Its impossible to accomplish any higher results in Mobster Rom V since modifying the GPU further then i did will lower Performance rather then improve it.....
However my test were done without overclocking you could try using my Rom with the Overclock Kernel to see if you get your 60 FPS in NenaMark 2
just did a retest of NenaMark 2 but on Mobster Rom V 1.0.5 and this is what i got (without overclock)
