Help tinny/buzzing speaker
Araldo
Member
Has anyone had problem with their top speaker sounding tinny? Hard to explain, it sounds like a buzzing when people talk. My girlfriends x doesn't sound like that. Anyone else have this problem? By the way, typed with swype.
yes it does it even when it is ringing when your calling someone. Mine done this from day one. My replacement should be here Tuesday. If you search there are a few other people having the same problem.
My bad. I did do a search but found nothing. I suck at searching. Thank you though.
If you take a bottle of canned air and blow air into the grill covering the earpiece it will solve your problem. My droid X and a few of my friends had this same problem and after doing this is fixed the buzzing/blown speaker problem.
Good Luck.
Good Luck.
I tried that last night, but it didn't work. I think mine is blown. :mad:
