Xruptor
Hey all!
I wanted to share the script I made to uninstall DarkTremors A2SD script. Apparently there really isn't any good uninstall method for it unless you use the command /a2sd remove. That doesn't fully get rid of the script and all it's files. I wanted to COMPLETELY remove A2SD from my phone. This means scripts, logs, and all files related to it. So I made a script to do this
Please note this only works for CM7!! I'm not entirely sure for CM9.
If you want to go from A2SD to S2E for CM7 this is what you have to do.
Follow these instructions exactly!
That should enable S2E without having to keep the files associated with Darktremor A2SD around. It works perfectly for me and I was able to go back and forth between A2SD and S2E easily.
I hope this tutorial and script helps someone
- Make a backup of your phone using CWM. I don't care if you already have one, do it again. I don't want people complaining that something went wrong.
- Download my A2SD Uninstall script. dt_a2sd_uninstall.zip
- Put my A2SD uninstall script on your SD card to install later with CWM.
- Download S2E and install it.
- Launch S2E and press the menu button then go to Settings.
- Check the box for Mounting SD-EXT as EX4.
- Go down to the import option and click it once to import the Darktremor A2SD settings.
- Reboot your phone and go to CWM
- Select 'Install from SD' and select my A2SD uninstall script.
- When it finishes reboot your phone
