wetbiker7
Extreme Android User
THIS WILL WORK WITH CTMOD 3.5 ALSO !
Hi all , I just wanted to post this seeing as there is no actual thread heading that states this will work on CTMod 3.2 . I've had several people ask me how to get in to DM mode on CTMod 3.2 and if their PRL can be changed . Well it can when you use the method below .
Thanks go to Monster for making this script available to CTMod 3.2 and CM7 users that do not have access to the hidden menu and only want to change their PRL .
I just tested this myself , changed my PRL and it works great . I am running CTMod 3.2 at the moment . DUH
The instructions are easy enough . Just download ScriptManager and Monsters DmCm7 text file located in the first post of his thread . I will post the link to that thread below .
Open ScriptManager and go to the DmCm7 text file on your SD card . Tap the DmCm7 file and make sure to tap SU before you tap Run at the top . Now you are all set to follow the prompts . E to enable and so on .
This will allow your computer to read the phone on a COM port which in turn will allow you to use CDMA Workshop . I hope this helps you guys and gals running CTMod 2.3 that wanna change your PRL . Please remember that Monster made this possible .
Here's the link to his original thread . Make sure that you hit the thank you button when you go there .
http://androidforums.com/galaxy-prevail-all-things-root/496242-script-dm-cm7-v1-2-update-2-10-a.html
Thank you very much for taking the time to read this and I hope you have an awesome day !
