Tip - "HOW DO I" Settings with Android
i have run a search all over and sorry to say i can't find my answer so will have to ask it here
i have the note 2 (uk) and im using aquamail as my email program as this suits my purpose better the problem i have is
when i click share and the email option it says no email configured as its trying to use the standard email program is it possible to set my email program as the default and if so how please
if there is a post then just a link to that would be really helpful thank you very much
Ps im new to android having just moved from blackberry after 12 years lol
George
Welcome George!
Have you setup this aquamail thru the default email app? Or is it a separate app?
I think you may be able to disable the stock email app but not sure.
Also, would you like me to move your post to the Note 2 forums? :)
Hopefully we can get this resolved for you:D
Everyone else is looking to get out of there evo or at least thinking about the idea and I'm buying one. Yea I know at some point it won't be supported by anyone and that isn't too far out but I'm buying one as a PDA/media player for the wife. 64gb sd card and off to the races. She will not be use any phone features this is just going to be a mean wifi using mini tablet e reader movie watcher day planner ect. It won't have mobile Internet so I need to load it with apks that don't require Internet. I will be rooting it straight off. I haven't had the chance to read the process but I'm sure it'll be a lot easier than my Casio 771. But yea I have no intention of trying to reinvent the wheel so any tips and tricks will be welcome. Anyway here I am and thanks in advance for all your collective work on this platform I'm excited to see what all the hype was about 4 years back.
I have android version 2.3.5 htc phone
I set up mail for 3rd party email
it seems to get mail every 15 minutes or so
how do I set the email retrieval time - so it can check every 5 minutes or so?
Welcome to Android Forums.
What device are you using and what app are you using on that device?
... Thom
Hi Thom,
it is just a simple sprint 4G - HTC phone - model PC 36100 (pre paid) and has android version 2.3.5 - no other info that I see
I was using the built in mail app.
Thanks Thom
also there is a small circle with arrows that I would think is the manual get mail button but it does nothing - so how do I force "gte mail" manually?
