Auditor_Kevin
Hey All,
I did a little searching and didn't see this thread posted in the forum, so I figured I'd share. Apologies if it has already been posted.
If you download the free app called "wifi analyzer", it can help you make an instant wifi connection with the Droid X.
As some of you have reported (and I have personally experienced), it can take too long for the phone to connect/reconnect with your home wifi signal.
Solution:
Toggle on Wifi, then immediately open Wifi Analyzer. For some reason, it forces the handshake almost instantly.
Wallah! You're connected. And in a fraction of the time compared to if you let the X just run its course.
Hope this helps some of you.
Kevin
Solution:
Kevin
