Root [Tips] how to emulate internal storage
k28king1
Since I have had my htc one sv, I have been using an app called foldermount to add internal storage space by using the external sd card. I bought the f7, but I was terribly upset with the amount of available space for games and apps.. After I rooted using FRAMAROOT, I installed foldermount. What it's does is emulate the internal sd space for large apps... when you load it it will ask for superuser permissions, than it will analyze the apps starting with the largest..once you choose to mount existing internal app data to the external sd,you must pin the data so that your games and apps will work. It is fairly easy to use. Essentially this acts as a way to supplement the internal storage with up to 32Gb of space depending on the size of your external sd card. This is also available in the play store as well.
you save my live jaja beacuse damm two things this have in problems sdcard program mover and gps
I felt that not enough people knew about this..kinda like my duty to help everyone learn how to do this to supplement the space..
No problem, I thank the dems who made the solution, I just pad on the knowledge..android may require tinkering to make things work great, but that is what I think makes it a lot better than ios
Thanks for the info on this app. It seems to work great.
With the free app you only get to move 3 apps, but the paid version is only $1.99 and then you are unlimited.
So I did this and moved my slacker radio app to my sd card, but it still shows it as using internal storage. What do you think about that?
nevermind, it seems to be working great.
