Tips & Tricks :)
suhel28
  1. *#*#4636#*#*
    This code can be used to get some interesting information about your phone and battery. It shows following 4 Menus on screen:
    1. Phone information
    2. Battery information
    3. Battery history
    4. Usage statistics
  2. Home, Back, Back, Home, Back, Home, Home, Back
    Lock your phone
    press home button once. The phone will light up.
    PRess the following key sequence simultaneously
    It shows following 3 Menus on screen:
    1. Sevice Info
    2. Service Settings
    3. Service Tests
  3. If you want to hide images and videos from gallery/videos
    No need of any image/video locking software
    • just push your files you want to hide in a new folder
    • in that folder create another folder and name it as .nomedia
    and you're done
    CAUTION !!! : if you create .nomedia folder in your root directory than it will hide all the images/videos on your phone
if you've any post them... :D
and you're done
--- how can you "unhide" it again? Do I need to change the name back to its original image name?
