Help Tired of being "always connected"
entimsu
I cant seem to find a connect on demand option, for my p500, and the always connected feature, eats my battery.
What I
To disable all internet data, just uncheck "Data enabled", all options are normal Froyo settings.
Connect on demand should work, if you disable "Auto-sync" under Settings / Accounts & synchronisation (maybe also "Backgroud data", be careful, some programs need background data) and also disable automatic Market updates. Still, if you leave "Data enabled" checked, some programs (weather widgets, Facebook client) can try to connect.
Thanks for the advice,
Anyhow, I enabled the "Connection Manager" widget, and even though I have to manually enable/disable the 3G and WIFI, it does the trick.
