Root Titanium and Root Explorer on GB
TryingToRoot
Any actions made by either program fails and reboots phone. do you think we will be able to address this on development? Just wanted to make our awesome devs aware.
This was a issue for me also except Titanium was able to delete the stuff I requested. I deleted task manager by accident and had to Odin again to start over fresh. When I went back into Titanium the 2nd Odin around to remove the bloat the forced reboots weren't happening anymore. The only thing I did different was I updated Superuser before trying to do anything with Titanium again.
are you guys remounting teh system as r/w before making these changes?
you prolly need to update busybox/su id do it for the one click but the gb only versions i have would mean a massive overhaul of the one click to make sure the precedent and replenish (both on froyo still) could get root/busybox
This right here.
Before, Android Mate worked, but it didn't have a Mount RW function. I downloaded ES File Explorer, which has a Mount RW toggle, and it works great... Thanks for your help, Shabby!
