Help Titanium Backup & GS3 external SD Card
HDKorp
Does anyone know how to use the GS3 external SD Card for the backed up files in TB? I can't find anything in the settings.
Sent from my $.96 GS3 using CleanROM.
After going through the settings myself, I thought I was doing something wrong. Then, in another GS3 forum, Brewer replied...
Brewer - from another GS3 forum said:
You're wanting the external SD card to be the designated location where TB saves the backups correct?
Like before, hit the menu button then preferences, then backup folder location. Mine defaults to "storage/sdcard0/TitaniumBackup". If you hit the back button it puts me at "storage/sdcard0" and hit the back button again to go up another layer to "/storage". In that folder "extSdCard" would be to folder to store it under. Are you not seeing the external SD card there?
Problem solved.
