Number1Gsxxr
I recently got an Atrix and I'm trying to transfer the apps from my Captivate to it. Both phones are rooted and have the same version of Titanium Backup installed. The Atrix build number is 1.8.3 if that helps.
I backed up just the apps on the Captivate and copied the folder over to my computer. I then copied the folder over to the Atrix. When I go into Ti Backup on the Atrix, in the restore section under batch, zero apps are listed. There should be approximately 50 apps I'm trying to restore. What gives? Has anyone come across this before? Am I going about this transfer in the right way?
Any help is greatly appreciated.
*Edit* Mods, feel free to delete this thread. Or leave it up in case others run into this issue. I figured out the problem. Selecting 'Backed up' instead of 'All' under the Filter by status in Ti Backup revealed the missing apps.
and yes I want to leave the thread incase other have the same issue. Glad you were able to fix it.
