Root Titanium Backup problem
holmgren
I am trying to batch restore all of my apps and it gets to about 4% and the phone restarts. I can not figure out why it is doing this. I have used it many many times before and never had had this problem. Though I know it did start when I loaded up CM6 and it also did the same thing. I am now back too BB .04 and it is doing the same thing. I assume it is some corrupted file somewhere?
Anyone know how to fix this issue?
Did you try the "problems" tab in the app? I generally don't have problems with TiBu but every once and a while it doesn't seem to like the busybox installed, and restores tend to act as you described. The Problems tab will reinstall it for you.
Also you may want to try the "fix Permissions" option in ROM Manager. I actually have no idea if that would help but if I'm stumped it tend to hit it for the hell of it
