Root Titanium Backup Problem
Joeydroid
When i click on batch, then run to backup my apps it jumps back to the Backup/Restore screen with all the apps, nothing gets backed up. I have backed up before with Titanium and it worked. I reinstalled Busybox, didn't help.
If i uninstall and reinstall will i lose all the things i did like freeze apps etc ? When i try to update through the marketplace it says installation error, package file was not signed correctly.
Sounds like TB didn't do it's job. Are you using the free version or the donate version? I've known people to have a few issues sometimes with the free version. I do notice you said you've used it before, so I'm not sure what the issue is. It does sound like busybox in a way, but I could be wrong.
