Root Titanium Backup Question: Sense ROM to Vanilla ROM?
dcesq06
Question that I haven't found the answer for - if I go from a Sense-based 2.2 ROM to a vanilla 2.2 ROM, can I use Titanium backup to restore all of my data, apps, etc.? My concern is that Titanium will attempt to put Sense system files onto the vanilla thereby causing a mess.
Thanks.
That's what I was scared of. Looking through Titanium, I can tell some of the settings/apps that go to Sense, but not all. Just don't want to mess anything up with a strange hybrid mix of Sense/Vanilla. But, on the other hand, I also don't want to repeat setting everything up.
Just restore your apps+data not system settings,data
I tried it and no problem
Yup as long as you just use it to restore apps it will be fine. I used it going from rooted stock to CM-6. Just be careful what apps you restore because some of the stuff titanium will have backed up is HTC sense stuff.
Just got off with VZW. They said we are getting the above mentioned and it will be announced tomorrow. FYI
You do realize that people working in call centers will just tell people like you whatever they want to hear to get them off the phone?
