cdadams1223
I've flashed several ROMs and have used TB every time. I typically have no problems. My question is this: when you guys backup your stuff, do you select the 'apps' backup or do you backup 'apps plus data'. The reason I ask is simple...when switching to a new ROM, if you've backed up your apps and the data on that particular ROM you're using and switch to another ROM, won't the data on your backup potentially interfere with the new ROM? Sorry if that sounded convoluted, but that's the best way I could put it.
So, is backing up your apps the best way to do it?
Thanks!
Thanks!
