oldTech
Need some help here. I'm getting the "your settings will prevent you ffrom being able to restore" message in Ti Backup. I've set the "mock locations" option. I've attempted the sideloading enable commands on the Ti Back website and the ones on the xda site ([How To] Enable Non-Market apps on Captivate (consolidated) - xda-developers) which was linked from this forum.
I am rooted. I am using adb shell from sdk tools. I usually get "not found" when trying all the commands. From what I can tell, the commands are using sqlite3, which I can't really find (mainly just don't know how). I think I also have two versions of busybox installed, one from installing the root.zip and one from the market.
I am not very savvy with the unix commands so i'm sure most (or all) of this is just me.
My main goal here is to at least get to the point where i can reinstall my Ti backups if I really goof stuff up. I really want to upgrade to 2.2, but trying to work through step by step.
Thanks in advance. Ya'll are great in helping everyone out.
p.s.- my Captivate is a pre-launch HW prototype but the software and kernel appears to be the same as everyone else.
