titanium help
1iwilly
ok on the sense rom for some reason i can't update the titanium proggie if uninstall it and try to install an up dated one it either get an error message or it says not install
is it the free or paid version? can't remember if sense ROM had titanium pre-installed. "roundabout acquired" paid versions can't be upgraded without paying for it; it'll come up with an error. you should be able to upgrade the free version with no problems.
yes the sense rom comes with the pro version but version 3.8.9.2
Why bother to update something that already has pro? :P unless you have like 4.5.2.2 of titanium and a pro key. If your trying to install an apk from the internet instead of the market thats the last update, or any other update, then it will barely even work. Youd have to update from market to update titanium. You could also remove the titanium that came with the rom but it's better not to as it may harm your phone.
