TB Pro. I have TB and Dropbox on a Captivate. All works well...backups go into a TitaniumBackup folder, syncs into Dropbox--same folder name fine.
Now trying to set up the TB/Dropbox operation in CM7 on a Nook tablet16. Nothing I can do seems to work. I do not want the backups in a folder named TitaniumBackup (same name as in the Captivate) because then in Dropbox, they will mingle with the files from the Captivate.
So, I created a new folder, TitaniumBackup-tablet. I set that in TB as the "remote location" for Dropbox and for "Box" (whatever that is); I also changed the "backup folder location" to TitaniumBackup-tablet. It asked if I wanted to move the backup to the new location, and a yes answer did that, and deleted the TitaniumBackup folder. All good.
I also, in the web view of Dropbox, created a TitaniumBackup-tablet folder (to 'receive' the files when they get into the folder in the tablet and upload to Dropbox). I also see that folder name in Dropbox on the tablet. Yet nothing I do will get the files from TitaniumBackup-tablet folder in the tablet to show up in TitaniumBackup-tablet folder of Dropbox --either the folder showing in the tablet or same name on on web.
OK, I know there is something stupid I am doing. Somebody clue me in. You are authorized to call me stupid if you feel compelled!
LATER: For a while post showed no paragraphing--not my failure!
