BATTERY MOD
• INSTRUCTIONS
> 1: Copy .zip to SD Card
> 2: Reboot into Recovery
> 3: Wipe cache/dalvik-cache
> 4: Flash .zip via recovery
> 5: Reboot
• DOWNLOAD
> http://goo.gl/kv5lVP
• PREVIEW
• EDIT INSTRUCTIONS
> 1: Extract the .zip on a computer
> 2: Decompile the framework.apk found within
> 3: Edit /res/drawable/stat_sys_battery.xml (change to amount of images in your set)
> 4: Edit /res/drawable/stat_sys_battery_charge.xml (change to amount of images in your set)
> 5: Add new images to /res/drawable-hdpi/
> 6: Compile framework.apk
> 7: Recreate .zip and flash
* I did not create these images nor do I take any credit. All I did was put together the .apk
the fine print: if it messes up your phone in anyway don't blame me... thats why phones don't come rooted
> 5: Reboot
• DOWNLOAD
• PREVIEW
• EDIT INSTRUCTIONS
