I've had 2 Fascinates and they don't even sniff the battery life of my Incredible. Incredible gets 30hrs on a 1500mah battery . My Fascinate not even being used with die with in a day , and it's not a rogue app as the phone has no aftermarket apps on it. It's just sitting in a drawer . I had so much hope for the Fascinate and it let me down. I even get it out and try messing with it in hopes I can get it to work some what decently just because the screen is so brilliant
I'm with you on the battery life. I'm getting 8 hours tops, and only barely messing with the phone.
I can't find a "rogue" app, either.
My incredible would get 6-7 hours, but the SF isn't that much better. Why the hell don't companies test out their phones for "real world" usage? Would the engineers want a phone that dies before they get home from work? Come on.
Give us a minimum of 16 hours battery life. They could've given this a larger battery (1800-2000 mAh) and tweaked the power draw of some of the components. Nuts.
My Ally can last two days under moderate usage without any live update widgets running. Even with some more usage, going one and half day is no problem. Can you guys confirm this for Fascinate? I like upgrading the screen size, speed in Fascinate but don't want to downgrade battery, GPS.
i personally moved from a Ally to the Fascinate
i am a very heavy user, pandora streaming hours a day, browsing randomply, occasional youtube viewing, two email auto sync's running, beautiful widgets live weather running......and i run my screen at 80% brightness.....and some #andchat in there too....i also use the camera most days for work documentation.....seriously, my phone doesnt go 20 minutes without being used....which is why i dumped my Ally for the Fascinate, the Ally just couldn't keep up with me and started rebooting randomly to top it off
battery life is roughly the same when not pushed however i find the Fascinate lasts longer when you use it hard
for instance, i stream Pandora several hours a day at work, the Ally went dead on me more than twice in a 10 hour day. The Fascinate, even while running an overclocked kernel and all sorts of widgets and stuff going on, automatic personal gmail and auto company exchange email, etc....all running, my Fascinate still makes it home with 20% or so.....only once did it go dead
with both devices, when i sit at my desk for lunch i plug it in....just so you know, but my habits stayed the same, i just switched devices from Ally to Fascinate and it was an improvement
Thanks for sharing your experience with both phone. I wish majority of SF users enjoy that good battery life like you are getting. Some folks on this forum seem to struggle to get one day usage out it for whatever reason. I think that could be either defective battery, weak signal reception or something wrong in the setting, apps running that can happen in any phone.
I read somewhere that SF has battery life control setting somewhere in the setting menu and I wonder what it is. And how do you feel about call quality, GPS performance in both phone? Ally is pretty good on those. GPS is fairly quick and accurate.
There is something wrong with mine then, because it is 5:15 pm where I live, I took my phone off the charger this morning at 6:00 a.m. So that is about 11 hours. My battery usage says the phone is 3 hrs 47 min and 18 secs since unplugged. Which is incorrect.....It has not be back on the charger all day.
This is the screen I took before plugging it in for the day. Add about 3 hours to this since I rebooted the phone yesterday in the morning to try out an app. I didnt hammer the phone but I used it normally.
