Help Toggle for default call blocking
WilfMoralee
Hi
I want to start using the call blocking built into the Android ROMs (not separate app, just in calls setting menus), but would love to find a way to enable/disable it quicker. Does anybody know of a separate app that will put a widget or shortcut on desktop that will toggle this?
I'm not looking for 3rd party app to actually do the call blocking, but failing finding the above can anybody recommend a good call blocker (i.e. one that does not let the phone ring at all) that will preferably block SMS too?
