toggle widget stopped workiing
lisadawn
Member
My moblie on/off toggle switch stopped working. I removed it then reinstalled it from htc widgets but still won't work. Anyone have this problem?
people have reported the toggles freezing up. removing and readding usually works. try removing, reboot, and readd.
I have had this problem once or twice, but I'm not sure what triggers the behavior.
I have found that toggling in and out of Airplane mode seems to correct the behavior of the Mobile Network toggle widget - without any need to reboot/uninstall/remove shortcut from home screen, etc.
HTH
eu1
