Hey everyone, I'm legible for a phone upgrade and I want the Galaxy S, but I think it's just too much! Is there any way I can get rid of the $30 internet plan and like put on a cheaper one? Like $10 or $20? Thank you!![]()
As SamsungVibrant mentioned, only loyal customers (usually 4+ years) will get any kind of discount. The higher cost of internet is facilitated by the added features and capabilities of the device. If you bought an Aston Martin, would you put regular gas in it? No, because it requires premium (and in some models, 96+ octane). Cheap internet = cheap phone. Expensive internet = expensive phone.
Personally, T-Mo required me to upgrade to the $25/mo data plan over a year ago with a Blackberry I had purchased. I accepted only when they offered me a $10 discount for life on my other services, since my last data plan was $15. I've been with them for 5 years now though.
Totally off the subject, but where exactly do you find 96+ octane gas other than an airport or racing supply? I haven't seen a rating that high since the days of leaded gas.
Its called racing fuel.
cam 2 is around 100-110 octane.
but do not put it into your regular street engine.
edit:
Sunoco Stations Sell 94.
76 stations sells 100.
Maybe I should take my friend's Toyota RAV there and see what happens!on a sidenote, if i get a captivate... could i unlock it and use t-zones with tmobile? can tmobile check the captivate's IMEI?
like it was said u will only get edge. However i think the Canadian vibrant which runs on bell might work...maybe t-mobile doesn't have bells imei list
Yeah...that was my reference to a racing supply shop. Can't recall ever seeing 100 octane at 76 though! Well, not in a very long time. The reference to an airport...I've heard of people with hot cars going to the airport to get fueled up for race day. That's pretty high octane stuff too.Maybe I should take my friend's Toyota RAV there and see what happens!
of course. that's not what i was asking though. let me clarify.
the vibrant won't run on t-zones because they check the IMEI of your vibrant. they then decide that a smartphone shouldn't be using edge and block your connection.
my question is, if you get a captivate and use it on tmobile's network.. would they be able to track your IMEI and prevent you from using t-zones?
they have 100 octane here but thats at a VP racing gas station in town and its like $7 a gallon. they also have 93 octane which is usually unavailable on the west coast.
also using high octane fuel in a low compression engine will not gain you any more power... you only need higher octane with high compression/ forced induction engines because the fuel burns slower and prevents predetonation.
if you get a captivate you most like will get away with using the ten dollar t-mobile data plan. But and this is a big but...captivate does not have the proper t-mobile 3g bands...thus you will get edge speeds. This is why i suggested bells vibrant, bells vibrant may have the proper t-mobile 3g bands while t-mobile possibly not having the bell vibrant imei numbers.
The only real lucky ones are att customers. ..They can use a vibrant and get 3g via the vibrant 1900 band...but vibrant does not have 3g 850 band for att. You can find the band option in the phone but turning it on does nothing.
I see 92 octane around here, at least last time I checked. $7 a gallon? I'll stick with my tired old '03 Cavalier for a while.
I know about the compression/octane situation. I was thinking maybe RAV's ECU would advance the timing a bit...maybe help it smoke those front wheels off the line!![]()
Here in San Diego, there are a lot of super expensive cars, so the gas stations in places like Rancho Santa Fe and Fairbanks Ranch have the high octane pumps to fuel all of the Lambo's, Ferrari's, and Aston Martin's. Last I checked, it was about $8 per gallon in RSF, as that's one of the richest towns in America, so they gouge the price a bit.
do account transfers count? i've been with them for 6+ years.. but 3 years ago i switched over to my aunt's family plan. then i last year i went prepaid... so technically i've been with tmo for a while. i don't think it'll count though.
I have a neon srt-4... 21PSI of boost... yeah I wish I had 93 octane lol.
I dont think the timing will advance with the same fuel pressure and amount of air. If i remember right timing is mostly based on A/F ratio. higher octane fuel doesn't change the AFR any. cars and bikes are my other hobby other than computers and gadgets. haha
I got the loyal customer discount by calling T-Mobile and asking for it. You could try that.
