dan55 Android Expert Dec 20, 2010 #1 hi all in last couple of days I've started getting lots more force closes on many apps are these due to lack of memory? the changes I've made recently are doing the htc upgrade and installing go launcher. cheers dan
SUroot Extreme Android User Dec 20, 2010 #2 If you haven't done the "force apps to SD" steps, its probably an OTA update that has caused this. If you factory reset it will probably cure this.
dan55 Android Expert Dec 20, 2010 #3 thanks dan.will try that then.yes I've had to pushed os updates this week I think cheers dan
dan55 Android Expert Dec 27, 2010 #4 ok - done a factory reset so fingers crossed - took about 4 hrs to rebuild it i reckon!
