Too many pattern attempts sony xperia X10. locked out
You need to go to Sony Ericsson's own website and search for Sony Ericsson Update Service. The links above don't seem to be working - I will try and fix them but the website is based on your world location anyway so probably best to get the download applicable to you.
i have no internet on my phone which means i cannot sign into my google acc. and when i try to connect it to the PC it doesnt connect because i cannot drag the status bar because i cant unlock my phone! I HATE THIS PHONE!! please someone help me :( i dont know what to do
You will need to run a reset via Sony Ericsson Update Service, not PC Companion, as the SEUS does not ask you to mount the phone.
Ha5. I also get the same problem.i ald try all the solution.some tell me to try password as null,and some ask to hard reset. But all the solution cant fix it. then i try my self. First U need to remove ur sim card,then turn on ur x10 without sim card. dial to 112 at emergency call. n touch ur screen,then should be a pattern pola out. try to change it. just enter the pattern from 3-2-1-4.that the easy pattern i think.why should 3-2-1-4? cause that is the minimum pattern that the x10 require. just do that n confirm the pattern again.then ur x10 can be open. Hope this solution can fix all ur prob. After tat dont use any pola to protect ur x10 again.. i ald try for 10 times. i make it locked then open again n again.and every times tis solution can fix.now i also not afraid too use the pattern again... Ha5. If need any confirmation or solution just email to me.. i will try my best to help u.
There was a suggested cheat... try typing 'null' into the password box. It worked for some people so might be just the thing for you! Let us know if it does.
you are awesome!!!!! after 3 days of being without my phone and numerous calls to sony to try to resolve this matter...the little 4 letter word null got me back into my phone. I was already preparred to ship my phone to them for repair. Once again , Thank you.
I have got the same problem, my X10 got locked out after too many attempts and i tried all the solutions like null password but unable to fix the problem. I tried doing the same as you guided but there is no pattern appeared. Plz help me out of this situation.please guide me either there is specific area of the screen where you have to touch or there is unique way of doing it. Or please suggest me some other possible solution to unlock my phone. Please your help will be greatly apprecaited. anxiously waiting for your reply...
Hi, I downloaded the update service. go into it and it says switch phone off for 30 seconds then plug the usb into the phone while holding the back button which im doing but nothing is happening? Just wondering if you could help me in anyway would be really appreciated. Thanks
Try the following link to hard reset your phone. There are three ways to hard reset your cell phone mentioned in the link. I use the option 3 and got my problem solved.
Sony Ericsson Xperia X10: Hard Reset
I have been locked out of my xperia X10 for enterin the unlock pattern incorrectly too many times. Although I have been given the oppurtunity to put my google account email and address in. It still won't work. My google account still works on my PC. I'm truly at my wits end and need help please... anyone? plzzz plzz plzz
this happened to me once. in the password field, enter the word "null" (no double quotes) instead of the actual password. you should be able to log back in
hi
it worked for me enter email address and password enter null and will take you to the pattern screen for new pattern..hope it works.
I had this problem only I forgot my gmail password cuz I never use it. I fixed it. This only works if you have a shortcut to your settings on your home screen.
When on the screen with gmail and password theres a emergency call option, select it.
on the call screen press back, you have a split second to select settings.
do it again when you press back it should show your settings menu
you have to be quick and press security
do it again and you should see the require pattern option at the very top.
the next time your on that screen you have enter your pattern as quick as possible, and that should solve the problem.
this will take a few attempts and be very frustrating, but be patient and you wont have to wipe your phone :)
just try this it works for my xperia 10i.....just click on your phone's user guide which can be found on the main menu.click search and type in "google account". choose "to delete google account from your phone" then just follow the instructions from there. ... . hope it helps
I just managed to unlock mine (eventually).. just switched off, removed sim card, switched back on and entered the correct pattern, then put sim card back in and switched it on again and it worked. This truly is the worst phone of all time, last time this happened I had to have a factory reset done and lost everything so thanks all.
Here is a tip....turn the pattern off.
Second tip....remember the pattern if you set it.
I am still amazed how there are at least 2 or 3 people a week that come on here to complain about how they set a lock pattern and forgot what it was.....somehow I don't think the problem is the phone's fault.
Thank you so much!! to every one else yuo must have alot of patients. i almost broke my phone i wanted to slam it on the wall from the irritation. This works even if you dnt have a shortcut on your home screen.
1) open slide, go to account info screen
2) go to emergency call (now heres where its frusterating BE PATIENT)
press the <- back key
3) very quickly press menu, Repeat 1 and 2 then hit security.
4) after this keep reapeting until you complete the patern removal.
the screen will quickly in a second keep going back to the slide screen keep repeating step 1,2. When the phone takes you back to the slide every time you repeat step 1 and 2 when you hit the bak botton the screen will be exactly where you left off.
what you got to go to is Menu, Settings, And Uncheck the (require pattern box) then the tricky and most hard part is entering your pattern You only have 1 second to do so.
*This only works if you know your pattern. My phone got locked because my nephew was messing with it.
More specific if my instructions werent clear. Txt or call 510)367-2118
totally free lol.
Dixoma1986
You are brilliant - password of Null did not work for me and i have been going around in circles for past 4 days. your suggestion of trying the emergency button and the back key through settings took a few attempts but has worked ! I could bake a big apple pie for you!!!!! thank you!!!!:):):)
This security feature in X10 is a joke . My x10 got locked and was not accepting my google account password . I typed 'null' as password and it worked .............. freaking ????
