. now i had succcessfully solve the problem of putting wrong pattern several times and lock the phone. hahahahaha
. had tried a several times like you say. SORRY BUT I DNT KNOW WHERE TO POST SOMETHING ON THAT FORUM. .i am from mauritius and my sister bought an xperia mini pro for me. .it was unlocked. .i connect my phone to my pc then i update something on pc companion. .and now it is lock. . :'( please help me someone
. I did everyting dat I wer supose to dew
. Still nothing
. To all Android users
, Bware of the way u dew ur pattern 2 lock ur phone
. Ur pattern seeker can b toooo slooooow or just toooo dammmmm fast. Its just tooo dam senci
. We need to write to Google on there Gmail Account, about this serious prob
hy frndz i tried all the thing thn tu ma phne lockd only ...
so plz help me out a
Thank you so much!! to every one else yuo must have alot of patients. i almost broke my phone i wanted to slam it on the wall from the irritation. This works even if you dnt have a shortcut on your home screen.
1) open slide, go to account info screen
2) go to emergency call (now heres where its frusterating BE PATIENT)
press the <- back key
3) very quickly press menu, Repeat 1 and 2 then hit security.
4) after this keep reapeting until you complete the patern removal.
the screen will quickly in a second keep going back to the slide screen keep repeating step 1,2. When the phone takes you back to the slide every time you repeat step 1 and 2 when you hit the bak botton the screen will be exactly where you left off.
what you got to go to is Menu, Settings, And Uncheck the (require pattern box) then the tricky and most hard part is entering your pattern You only have 1 second to do so.
*This only works if you know your pattern. My phone got locked because my nephew was messing with it.
More specific if my instructions werent clear. Txt or call 510)367-2118
totally free lol.
totally free lol.
I had this problem only I forgot my gmail password cuz I never use it. I fixed it. This only works if you have a shortcut to your settings on your home screen.
When on the screen with gmail and password theres a emergency call option, select it.
on the call screen press back, you have a split second to select settings.
do it again when you press back it should show your settings menu
you have to be quick and press security
do it again and you should see the require pattern option at the very top.
the next time your on that screen you have enter your pattern as quick as possible, and that should solve the problem.
this will take a few attempts and be very frustrating, but be patient and you wont have to wipe your phone![]()
totally free lol.
Mine has done the same. I do not recall having a Google account on it though, or if I do, I don't remember it. My friend locked me out, she was trying to play music and couldn't figure out the password. I tried the 'null' and got nothing. I'm now trying the thing where I take out the batter, sim and memory card for 10 minutes. Does anyone have anything else I can do that avoids the google login? Much appreciated!
am having the same problem with my sony ericsson Xperia X10 please i need help...hi
I have been locked out of my xperia X10 for entering the unlock pattern incorrectly too many times. Although I have been given the opportunity to put my google account email and address in. It still won't work. My google account still works on my PC. I'm truly at my wits end and need help please... anyone? plzzz plzz plzz
what do yu mean 1 and two I cnt do vit lolI had this problem only I forgot my gmail password cuz I never use it. I fixed it. This only works if you have a shortcut to your settings on your home screen.
