Top pull down qslide apps.
msaeger
Member
My phone updated to JB and now on the top pull down menu they added another row of stuff.
I figured out how to remove the apps from there but it still shows the bar anyway.
Is there a way to get rid of this bar or to put different apps on there? I don't really want any of the ones that were there and I can't see a way to add anything else.
Those are apps that multi task I would recommend trying its pretty cool.
Yeah maybe I just don't like having halftime the screen filled with stuff when I am trying to look at a notification. Plus calendar is about the only thing on there I use much.
I would love to disable q-slide. I was told to click this but I will be darned if I can find it on the screen when I swipe down and see q-slide. Mary
I really hope there's a way to remove the qslide apps without having to root your phone, because these are so annoying. They take up SO much space, it's ridiculous.
I posted back on the t-mobile forums asking the service rep to tell exactly where that icon is to remove it but haven't heard back yet. Mary
