Help Torch Light
So what exactly did you do too get it working? Just so the rest of us can use it :-)
If it does not by default (do you have this firmware to check?) then you need an app like this:
https://play.google.com/store/apps/...4.android.quickshortcut&feature=search_result
Open the app and on Activities tab search for 'torch'. Try to open it and it will open the screen where you can enable it and set timeout period. Done
If you have Apex or any other 3rd party launcher, try to add something to the homescreen and choose Activities. Scroll to Setting and choose torch Light. Then open it from homescreen and set it up.
I've still to upgrade firmware, been meaning to for a while but think I'll give it a go tomorrow if it's a feature available in default :-) thanks, and I'm glad you have managed to get the feature you were after.Lol
This update brings nice performance improvement.
The feature makes my life much easier as I use the flashlight quite often.
