gizmomaven
Is there an apps or widget to shows accumulated battery usage ie 5-6 hours etc otherwise how do I know how the good the battery is
Thanks for your advice but these apps don't appear to do what I want. I want an apps which gives me an accumulative total of battery usage ie on say Monday I used it for say 22 minutes, Tuesday for 18 minutes, Wednesday for 26 minutes and the apps states that I have had usage of 66 minutes.This way I can determine whether the advertised figure of 5-6 hours usage on my new tablet is correct.
Being now retired I only use my tablet when I go out, preferring my laptop when home
If that's all you're after, take a look at Settings > Battery. At the top, the graph should say something like "2h 57m 33s on battery" (just what mine says at this moment).
I don't want details of the daily usage just the cumulative total ie 5-6 hours or whateverYeah, but that doesn't list the days, like on Monday he used it for 2 hours and such, it just lists the total time.
Which I mean I guess could serve the same purpose of giving him total usage in one battery life.
I really don't know if there is an app that tells you each days usage though.
Thanks, have checked this out and refers "root uninstaller" whats thats all about
