have you tried clearing the data from your market app?
settings
applications
manage applications
all
locate market
clear data
clear cache
open market
menu
accounts
and select your acct
and then try downloading an app or updating one
For anyone suffering this problem try this! I'm not sure its a permanent fix yet or not. If not then the problem is related to "google services framework"
Goto Settings
i do believe i told you about that, minus the framework lol and you said it didnt work.. so did it temporarily? and yes im sure its on googles end, my google music hasnt worked in a few weeks, something about cannot load the stream.
Both my husband and I have no apps listed in our markets on DX. It just says "Applications and games owned by this account will appear here."
It's been this way for two weeks or more now. Getting very frustrating. It was this way on market versions 3.1.5, 3.2 and the current 3.3.1.1. So, it goes beyond a single version of the market app.
Has anyone heard any updates on this issue? I'm using AppBrain to try to stay current with updates but it's a pain. If people AREN'T having issues, can you please post ROM, root status, etc? I've heard of people having the same issue who are running stock unrooted OTA GB but I'm starting to wonder if it's some backlash against people customizing their phones. Having said that, it wouldn't be cool since that's part of the draw to Android - the openness.
Advice or suggestions appreciated!
