When i touch and hold at Home screen or on any other screen, its blank ..., NOTHING happens. So, I cant add widgets anymore or I cant move or delete the shortcuts which are placed on my screen before ...
Someone help me out ....
Reflashing stock firmware using KDZ is sure to fix the problem if it is a software issue, but before you do that, are you rooted? Which ROM are you using? Which launcher are you using?
I use CM7, GB 3.5 by mik_os
I ve already got this problem before but i forgot how to solve it ..
I got solution from this forum before, so i ve posted here again ...
But the solution is SIMPLE ... Thats what I remember ...
