touch pro 2 battery for hero??
heatbball
i have read that the touch pro 2 battery can be used in the hero. Can anyone confirm that it works in the Sprint Hero?
thanks
no pun intended but i did get a touch more battery life out of the PRO2 battery when it was installed in the hero. i eventually put the pro2 battery back in my pro because i use it more daily then i do the hero. but yes i did see some improvement in battery life/run time when it was indeed installed in the hero...
im only running google talk and the hero is unrooted so no other apps are installed on the device. i use BT, WIFI and the stock NFL widget on the hero 24/7...
i have a sealed andida 2000mah battery for the touch pro 2 (it works for hero and it doesnt need a new back cover) . I bought it about a 6 weeks ago (it came from china today) when i had a hero, but since i had to get rid of the hero i now have an extra battery. it is sealed.
the reason i bought the battery is because of the discussion below.
(the original discussion is High Capacity Battery. Anyone got a review? - SprintUsers.com)
if anyone wants to take it off my hands i just want to makeback what i spent on it (10 bucks) send me a pm.
(I have no idea if this is against the rules, please forgive me if it is)
i will say when i got my tp2 batteries from ebay the charger for them does not work for the hero's batt, other than that theyre great
Hi,
I sent you a PM..
false.
you can use the charger for the hero battery you just have to turn it around. I do this and havent had a problem at all. My original hero battery actually lasts longer than the batteries that came with the charger
