Help Touch screen issues, pleease help!
so the other day, my touch screen would not work sometimes; in other words, just being slow.
&when i shut it off &turned it back on, it would not work.
i've tried to reset it,
&it says
TOUCH PANEL-fail
please helllp :(
&what do you do when in recovery mode
&your phone goes to a picture of a phone with a triangle with ! in it?:(
&it says
TOUCH PANEL-fail
please helllp :(
Hey buddy!
Don't worry, it will be alright dude ;)
For starters, what phone do you have?
Keep well, and don't panic!
Regards
Stinky :)
mytouch 3g slide
Cool man!
Okay
1) Turn off ur my touch 3g slide
2) Hold down the volume button keep pressing and press the power button
What do you see?
I don't have that specific phone so can't know what you see there.
EXPRESSO PVT SHIP S-ON
HBOOT- 0.5.0000
MICROP-0620
TOUCH PANEL-fail
RADIO- 7.09.35.10
Mar 23, 2010,21:22:49
HBOOT
<VOL UP> to previous item
<VOL DOWN> to next item
<POWER> to select item
FASTBOOT
RECOVERY
CLEAR STORAGE
SIMLOCK
Whoa...
Okay then lets try re-install the os maybe i dunno what else to do go here now and select your phone:
Index of /shipped/
I don't know what else to do :(
wait what?
oh &if i hit recovery, there is a picture of a phone with a ! in a red triangle.,
what do i do next?
cause maybe recovery will work, since i haven't tried it.
wait what?
what do i do next?
Oh sorry about that! :)
Okay i think you hold down "menu" and then press "home" i think at least to get into recovery mode :)
nope :( it still stays there.
Hmm damn this is not good.
Okay, can you boot into android normally?
What i mean is can you boot into android regardless of the touch screen problems? We are going to try do a NAND backup i think that's what it is called.
But you will need root i think hang on a second buddy it will be alright :)
yeah, it will turn on.
but it will go to the lock screen; i can unlock it, but it gives me that whole "let's get you started" bull &since my middle button isn't working, i can't get past it.
&okay, but i have no idea how to root it?
Okay no worries dude!
Go here to root i don't feel like typing it all out no offence! :)
How To: Root the HTC MyTouch Slide (Exploid Method) (Updated 09.28.10) | TheUnlockr
And go here to learn how to put custom roms on but we will put the factory rom back on but go here:
How To: Load a Custom ROM on the HTC MyTouch Slide (Updated 09.28.10) | TheUnlockr
Go here for the factory ROM:
(ROM) Factory Rom..Champion build / Need Root to Flash First!! - xda-developers
I hope this works.
Sorry to bump this thread again, but I have the same problem. Touch screen doesn't register touch and the middle button went out. I was wondering if there was any success with this proposed solution. I've already replaced the digitizer and reset the phone. I just need to know if it's time to give up....:confused:
hey im only 14 and in the red triangle screen i pressed the power button and volume up button and dont know what to do from there
