Found these instructions at another forum, but followed them and they worked perfect:
Do the following for a simpler and more reliable ICS CM9 Alpha install. The idea is to keep it simple:
1. Download
2. Backup
3. Clean up
4. Install
5. Restore (if you used Titanium Backup or other apps to save apps)
6. Be happy
There is no 100% guarantee, but from what I have seenI believe below is the approach that is most likely to be successful.
Download
Download the four files below to your TP.
- CM9 alpha .6: (
Techerrata Downloads - Downloading update-cm-9.0.0-RC0-Touchpad-alpha0.6-fullofbugs.zip or
Goo-inside.me Downloads - Downloading update-cm-9.0.0-RC0-Touchpad-alpha0.6-fullofbugs.zip)
- Patch for the power menu reboot issue with 0.6 where TP shuts down instead of rebooting. From Dalingrin and team:
http://ergh.org/cmtp/
- Gapps 4.0.3 v11:
http://goo.gl/u9s8g (People have also had success with teameos gapps:
http://goo-inside.me...s/teameos/gapps)
- Gapps fixer: http ://goo.gl/UM5Ik (You should not need this, but should have it just in case.)
2. Backup
Backup installed apps or data (bookmarks, game status, etc.) in Android, using apps like Titanium Backup (TiBU) or MyBackup Pro/Root.
(Note: Previously, on ICS Alpha .5 only TiBU version 4.0.2 (
http://www.wuala.com...kup 4.0.2.apk) worked unless you applied a patch, but as of Alpha .6 the current release version of TiBU works w/out issue.) So don't worry about that any more...
Boot into ClockworkMod Recovery (CWM).
Back up your current ROM in CWM (also known as a "nandroid" backup) using the Backup/Restore menu.
3. Clean up
Still in CWM:
- Wipe Data/Factory Reset
- Format System (under the Mounts and Storage submenu in CWM)
- Format Data (if you're superstitious...wipe data/factory reset already did this, but I know some people still want to later, rinse, repeat. ;-) )
- Format Cache (if you're superstitious...wipe data/factory reset already did this, but I know some people still want to later, rinse, repeat. ;-) )
While you're in the Mounts and Storage submenu note the Mount USB storage option - if you get into trouble after the install, you can boot into CWM and use the Mount USB Storage option to mount the internal storage to your PC via USB to manage the files on your TP SD card from your laptop.
4. Install
Still in CWM:
Flash the following files using the Install zip from SD card option.
- ROM: update-cm-9.0.0-RC0-Touchpad-alpha0.6-fullofbugs.zip
- Alpha .6 power menu patch: update-cm-9.0.0-RC0-Touchpad-a0.6-reboot_fix-signed.zip
- Gapps: gapps_ics_4.0.3_v11.zip or EOS_GApps_ics_4.0.3_v10.4.zip, whichever version of Gapps you downloaded.
Do not flash Gapps Fixer yet...you should not need it with the recent Gapps versions.
Reboot...after rebooting and signing into your Gmail account, Market should auto-restore all your apps. If not install from market or from your backup.
5. Restore
If you used TiBU or other BU software, restore apps if they don't restore from the Market, or if you just want to restore them quickly. Generally, restoring data for apps may cause problems, but should be fine for games, apps that need log-in information, etc.
If you have problems with Market running or sync for email or calendar, you can try flashing the Gapps fixer zip file.
If you have ulmage issues (boot fails, messages about insufficient space or improper ulimage size, you may need to uninstall CM9 using the acmeuninstaller, and then reinstall CM9 using CWM. Check out this thread for more info/options:
http://rootzwiki.com...6-boot-failure/
The old truths are right - do a clean install on a ROM change or significant update. Using the acme option to try to keep data can be quite iffy...may work fine for some, but for most users it's not worth the potential hassle during and after install. If you do install from CWM, you must remove existing data first, per above steps.
