Help touchpad not turning on
AlexKP
Member
My touchpad is suddenly not turning on. I have CM7.1 installed and I've run into incidents in the past where I would press the power button once or twice and the screen would not immediately come on and it would finally come on when I pressed the home button. Anyone else run into similar problems?
The fix for SOD: Hold the power and home buttons down for AT LEAST 30 seconds.
See if that helps.
SOD is rare these days, unless you're on a old version of CM7.
I actually had this happen to my 1 day old touchpad. Talk about crapping your pants! Luckily a quick google search found the Power and Home button trick and I haven't had SOD since.
