TouchWiz 4.0?
yohannie
I was just wondering if anyone knew whether the upcoming Gingerbread update will also update TouchWiz from 3.0 to 4.0. I know the Gingerbread is pretty certain and is just a matter of time (I keep seeing new leaks from Samsung and the development team behind it seems to be nearing completing a build that will be stable), but what about TouchWiz?
Do you guys think we'll get Gingerbread but with the same Touchzwiz 3.0? It'd be interesting to know if anyone with the Captivate got a TW upgrade or not when they got their GB.
Ive installed 2 of the leaks and they both only had TW 3.0.
If you look over at the XDA forums, they have TW 4.5 you can install yourself(if you're rooted). Although it is a bit laggy.
To be honest, try out ADW launcher, far superior to touchwiz. Its a couple bucks but extremely worth it.
There may be an official tw4 but the customized one is way better anyway lol. Like the other guy said, the other is better though.
