Root Touchwiz ROM Rebirth
when i click on the file to download it says this file contains virus do u still want to download this file..............
Here is the bug free Touchwiz ROM:
4shared Download link : Micromax A75 ROM: TouchWiz ROM Rebirth
mediafire link : TouchWiz_ROM_rebirth.zip
For SS : refer my previous thread...
bro ....
1. SuperSu says there is no binart installed. and supersu cannot installed it, then close autometically
2. proximity senser not working for me during call
3. data connection icon double shows ...there is smal & big 'E' 'H' 'G' displays altrntly
4. network bar colour is not there
bro ....
su can b updated via play store....
no problem in proximity sensor...
choose color via sim management option in settings...
data connectin icon change as per network available... give me screens of urs...
play store says installed.....there is no update showing
during call screen goes black ..means lights off...& not turned on autometically
Sir, Force Close problem in the camera while Video Recording... Pls do something for it... Otherwise overall ur rom is Ekdum ZABARDAST....
not turned on autometically......by pressing power button screen turned on......
Proximity sensor issue fixed....... & if someone facing this issue.... report in this thread....... now only one bug as amolmendhe said ........ camera issue while Video Recording its f.c. should be fixed to make all bug free ROM
Hey DOC i dint find the Lockscreen settings where we can have the Samsung Glaxy S2's Lockscreen which was there in the TouchWiz ROM.
Please explain, how u fixed those proximity sensor issues???
